Thinking about adding forward controls to FXR
TIPS: 1) Drill the brake rod clevis pin cotter pin hole a little bigger to fit a stronger/larger diameter cotter pin than the tiny one that comes in the kit. 2) You will likely need to drill the shift shaft linkage attachment 1/4" hole larger to fit your shift linkage heim joint 5/16" stud. (You must remove & reuse your existing joints that are not supplied in the kit.) 3) You will likely need to "stretch" your existing brake return spring about an inch for the extra weight of the kit brake pedal. (The spring that's in the rubber boot where the brake rod goes into the rear brake master.) 4) I bought and needed to slightly modify to install an aftermarket Harley-type chrome brake pedal pad, which makes for a nice finishing touch! 5) I recommend buying/installing 6 3/8" chrome or stainless flat washers for the peg shafts and main brackets mounting bolts. (Bolt, lock washer, flat washer then screw it in.) Reason being just lock washers against the chrome parts = gouging & rust. I also bought 6 chrome lock washers as the ones in the kit are more like 7/16" than 3/8", too big. You can get all this stuff at your alternate Harley parts shop (the local hardware store!) A drop of blue Loctite on all the fasteners is a good idea too. 6) Don't forget to angle the pegs rearward to fold vs break if the bike should happen to tip or fall... 7) Grease the brake and shifter shafts & holes during assembly. The shafts ride on plastic bushings in the bracket holes, not the best but should last quite awhile if they’re kept greased. Haven’t done it yet but I plan on drilling the bracket shaft tubes and installing grease fittings in the near future. That’s about it I think...
If you have any questions or you’d like a few installed pics, just send me your email to jreinders_99@yahoo.com.
Good luck and Ol' Biker says get out in the wind!
Okay, I'm done with my rant.
Oh, and I bought a used Thunderheader off of Craigslist this week. It is for an Evo Softail, but I'm going to make it work!
