cam advise
Old Sep 28, 2010 | 03:09 PM
4 inch pistons's Avatar
4 inch pistons
Please pardon the dumb question, but does the idle sound change--- as it does on a car when you change the cam?
Old Sep 28, 2010 | 06:47 PM
Mike T's Avatar
Mike T
On a bike with a carb it does.
Old Oct 3, 2010 | 05:39 PM
phat96's Avatar
phat96
wouldn't mind more info on this, on my RK I used the 27 and it felt great, running through the gears, but it was noisy. I hear about the S&S cam and the vthunder cam and I wonder if it won't be a better choice.
Old Oct 12, 2010 | 08:46 PM
CaptJIM's Avatar
CaptJIM
I went with the EV-46 for my setup at the recommendation of my local H-D master mechanic. The EV-27 was also considered. Couldn't be happier with the 46!
Old Oct 15, 2010 | 09:39 AM
redrott's Avatar
redrott
I have an ev-27 in my 99 fatboy. I wouldn't put a cam in it again to save my life. It is going to be noisy after you do it and you will probably not like it. I had a pushrod rubbing also which made even more noise at first. I fixed that and even took the bike to Kendall Johnsons in winston salem to get looked at for the noise. Which he said was completely normal for that cam. The increase in power is not what you would be led to believe either I would leave the stock cam and stop at a air filter and carb jet upgrade.
I am so unhappy with the cam results my bike is for sale.
Old Oct 15, 2010 | 10:41 AM
grbrown's Avatar
grbrown
Cool
Our Evos all had noise limiting stuff on them as stock, including a very tame cam and quiet airbox. I found when replacing all that stuff the bike did indeed make a lot more noise! It was mostly induction, not mechanical, the sound of air being sucked in by each cylinder. The bike flew, in contrast with when it was stock, but I routinely wear ear plugs when travelling any distance, so soon ignored it. Got an S&S 107 in it now - that ain't quiet either!
monarchy
Mar 2, 2015 05:51 AM
jrdfatboy
Apr 6, 2014 09:12 AM
squidman
Exhaust System Topics
30
Apr 10, 2008 11:37 AM
TBone
Apr 15, 2007 02:37 PM
hawnstar
Feb 6, 2006 04:17 AM
