Hey guys. Looked at a 97 softail custom today. 20,000 miles and very clean and good price. Bike runs and starts like a top. No smoke or oil leaks. Nothing. Question is that you can hear an obvious ticking from the rocker boxes. Is this just a valve adjustment needed? I planned to pop a cam in it if i got it. So I guess I could just pull the heads at the same time and do that. Wanted to check first.
If you are going to put a cam in it, don't worry about the tick with 20,000 on it, the rockers should be ok. A good set of lifters, adjustable push tubes and you will get it out, don't need to pull the heads to do what your wanting to do either.
Yeah I was going to do adjustable pushrods and cut the old ones out. Didn't even think about the lifters. Thanks guys. It is a good running bike. Of course I am about to go look at yet another one. I hate looking around so much but want to make the right decision.
