Explain my decision?
Old Jun 6, 2011 | 09:18 PM
robo74's Avatar
robo74
Default Explain my decision?
So after buying this FLHT, I have decided that the suspension needs some TLC.
The back was easy, searched thru some past posts and found that a set of progressives was a good bang for the buck. Wise choice because its all good.
Now, the fronts.
Its not holding any air, I hear the click for the anti dive, but it constantly bottoms out and rides like poo poo.
So, do I find the source of the air leak, change the oil and see how it is?
Do I just install some new springs and call it done?
I took the outer off, and I must say, I am a little intimidated by all that stuff in there.
I have done my searches, but I am still on the fence.
I am looking for the best bang for the buck and was hoping for something I could do myself!
Old Jun 6, 2011 | 10:40 PM
Bama91's Avatar
Bama91
First off what's better for you rebuild or replace? Which is cheaper, gives a better ride etc. It's all intimidating the first time. I am digging into mine now on stuff I've never opened up. Sportsters was my thing now I've got an Evo and learning as I go. But if ypu decide to do it yourself, the guys on here are great and will go out of their way to help you. They have pulled me through a few rough patches.
Old Jun 6, 2011 | 11:18 PM
woodnbow's Avatar
woodnbow
You can buy a rebuild kit from Dennis Kirk or JP Cycles. Open the manual and go from there. Have patience there is a lot of crap to wade thru but you will get it right and properly functioning that front end is a pretty nice ride.
Old Jun 7, 2011 | 02:11 AM
Holster Maker's Avatar
Holster Maker
A lot of people put the Progressive Heavy duty front fork springs (for over 225 lbs) and 20 wt, which works real well. They are about $100 (J&P) and any shop will install them for 3 hrs labor or about $200...all done for about 300! With the fairing and all the stuff that's RR-ed I'll pay $200 any day.
Old Jun 7, 2011 | 05:26 AM
grbrown's Avatar
grbrown
If the forks are oil tight, the things that can go wrong with the air system are all relatively simple. The manifold on the top of the triple-tree has a few O rings and sealing washers, any of which may have a leak; there is a short piece of hose that may be split, or the clamps loose; and there is a tyre valve in the l/h end of the handlebars. If you bought new parts for all of those it will only cost pocket money! The only part I have replaced on mine, having owned it from new, is a valve.
Old Jun 7, 2011 | 09:47 PM
JimMA's Avatar
JimMA
I changed over to Progressive springs. Better then stock. Progressive now has a cartridge "drop in" that I would probaly do today which I "hear" is even better.
Notgrownup
34
Oct 25, 2022 09:20 AM
jluca
Jun 20, 2016 06:39 PM
d-streetglidr
Jan 25, 2013 11:25 AM
rolfsharley
Nov 26, 2012 10:59 AM
dz1087
EVO
Sep 12, 2011 12:57 AM
