New thread, same lighting problem.
Old May 12, 2012 | 08:13 PM
dub976's Avatar
dub976
Default New thread, same lighting problem.
Ok I have a intermittent problem with all of my lights going out except for the dash and hazards. I do have the hd r/t/b converter. I've replaced the breaker with a oem one as the aftermarket seemed to be junk. I've checked my grounds, all seem to be tight. The wires going into the breaker are clipped in tight. So now I'm confused as to what to check next. I'm thinking it's either a short before the wire breaks off in different directions or the signal convtor. 99% of my time riding is during the day so I'd rather check the wires with a meter then pull the convtor and do a wait and see approach.
Is their another point besides the breaker that all the lights connect at? Maybe under the dash?
Thanks
Old May 12, 2012 | 08:46 PM
RidemyEVO's Avatar
RidemyEVO
Your ignition swithc and in your handle bar switched, good place to check.
Old May 13, 2012 | 01:27 AM
dub976's Avatar
dub976
Double post.
Old May 13, 2012 | 01:29 AM
dub976's Avatar
dub976
I forgot when I post from my phone it doesn't show my sig saying the bike.
It's a 99 fatboy.
I did have to replace my ing switch last summer cause the tumble broke. I went with a aftermarket unit that was a 1/4 the price harley wanted for it. The only diff was the key no longer says hd on it.
What should I be looking to check on it? I would think its ok cause the bike still rides when it happens
Old May 13, 2012 | 06:09 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Remove the breaker for the lights and pop off the cover. If it doesn't look clean and new replace it.
Old May 13, 2012 | 07:54 PM
dub976's Avatar
dub976
Just replaced the circuit breaker last week with a overpriced hd unit.
Could I put a blade fuse in to Check to see if it's a short by having it pop?
bigrobtemp
2014-2024 Touring Models
13
Apr 5, 2018 04:58 PM
GdaddyHotRod
Electrical/Lighting/Alarm
Apr 2, 2014 10:40 AM
Medicjaycook
Oct 28, 2011 07:54 PM
RoadNames
Oct 5, 2008 09:25 PM
mike b
Feb 12, 2006 02:29 PM
