Primary Chain
Old Oct 10, 2012 | 07:33 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by texashillcountry
I put the OEM chain adjuster back in and ran it all the way up and still had too much slack in the chain.
Stretch and elongate are just about the same thing aren't they?
No, the chain gets longer because the pins are running inside an elongated opening in the side plate. The chain does not stretch.
Old Oct 11, 2012 | 11:50 AM
jokenroll's Avatar
jokenroll
Aren't we simply supposed to run the chain until we cannot adjust it anymore with the tensioner? At least according to the manual? And then change it together with the sprockets (it's a good practice anyways to always change a chain together with sprockets)?
Old Oct 11, 2012 | 12:38 PM
grbrown's Avatar
grbrown
Quite right JR. In reality the larger sprocket will tend to wear less so it may be possible to get more life out of the clutch (in our case).
Old Oct 11, 2012 | 04:02 PM
Uncle G.'s Avatar
Uncle G.
I don't know what you guys are doing to wear out your chains that fast. I've never had a chain stretch to that degree. I realize that you should replace chains and sprockets as a set (at least the small sprockets), but as I tend to change mine early, I'm not seeing much wear on the sprockets, as it's the worn chain that wears the sprockets.
Old Oct 11, 2012 | 05:06 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Why should you change the compensating sprocket with the chain if the sprocket isn't showing much wear? Can't you just change the chain and call it good?
Old Oct 12, 2012 | 04:31 AM
Uncle G.'s Avatar
Uncle G.
If the sprockets are good (not showing any "hooking" of the teeth), I'll just change the chain, but then, I try to change it before it's worn out.
Old Oct 12, 2012 | 08:41 AM
BIGRED1's Avatar
BIGRED1
I had over 200K on an OEM chain so when I installed a 113ci, I stayed with the OEM.
Yes, if there are sharp or hooking teeth, the sprockets need to be replaced.
As the teeth wear down, the chain will seem streched.
All in all, it is good practice to change sprockets at the same time as the chain. It is also a good time to replace the tensioner shoe, that is another area where wear will cause the chain to seem streched.
Old Oct 12, 2012 | 09:15 AM
evofloyd's Avatar
evofloyd
I love Harley , but they still pi$$ me off. New Primary/tranny fluid. How the h$ll do you go from 85/140 to some thing thin enough to run in a clutch. My manual calls for 3 diff #'s for all 3 holes. What the heck, I ran it one week, till it kept getting hader to shift and banging in to gear, back to Bel-Ray gear saver after that ride. I think heat {where you live} has alot to do with primary chain ware and how long they last along with proper adjustment and of course, how much you hammer on it.
Old Oct 12, 2012 | 10:56 AM
evofloyd's Avatar
evofloyd
After doing my primary side Checked it after about 200miles and the fluid was dark again. Changed it and again after 500. Think it helped save the clutch by flushing all the crap out ofthe plates
Paul32730
Feb 21, 2025 04:35 AM
sgw1064
Jan 8, 2023 09:19 PM
jimski
Feb 21, 2021 01:31 PM
jpooch00
Dec 21, 2012 08:24 AM
DaShoveled one
Feb 8, 2008 11:18 AM
