Ign. info needed
I've found a '98 Carbureted, factory-bone-stock FLHR that I'm interested in and just need to know for sure that it has the same ignition system (basically) as my '94 Evo. The current owner is clueless and out of state.
I'm pretty sure that all the carbed EVO's are the same, but I need some expert advice ASAP to be certain.
Also, did the '98 EVO's come from the factory with the Timkin inner cam bearing and updated lifters?
Thanks in advance.
Thanks in advance.
Also, did the '98 EVO's come from the factory with the Timco inner cam bearing and updated lifters?
Thanks in advance.
Thanks in advance.
Im not positive on the ignition so I will not respond. (but I think that they are the same)
My 98 did not have a torrington bearing nor the updated lifters.
for $300 (excluding pushrods) you could put a single fire ign. and OEM "B" lifters in it if you shop around
It took me over 2 years to find a bone-stock, low mileage black RK that hadn't been fu*ked with, which is what I held out for. The only thing I'll be doing to it is installing the updated lifters and inner cam bearing and NOTHING else (other than riding and enjoying it)!
Thanks again and ride safe.
Thanks for the response and ride safe.
