Dyna tank on RK?
Anyone know if a 1997 Dyna fuel tank will fit a 1997 Road King? I saw a local carbed Dyna tank for sale, and thought it might work for my carb conversion on my 97 Road King. I know the fill hole on the Dyna is different, but other than that don't know much else.
All you need to convert your RK tank to a carb is a Pingel tap and adapter kit. That includes an adapter to take the tap and a blank to fill the other hole. On the other hand, if you are after a custom look, I don't know if a Dyna tank will fit!
grbrown,
Thanks for the reply! I have looked into the Pingel adapter kit. I know you need to use a cut off wheel, and do a little work to get the Pingel kit to work - as well as be careful not to blow yourself up, while grinding
I figured if I could get a carbed tank cheap enough in decent condition, I could save the time cutting down the EFI fuel port.
I have a later EFI tank on my carb bike, with only one outlet, but the Pingel adapter kit I bought came with a threaded blank that I didn't need. I'm not sure why it should be necessary to use a cutter, if earlier tanks have two threaded outlets. I'm glad the Atlantic is between us!!!!
grbrown,
I am assuming with the Pingel adaptor, you will need to do some on the EFI tank to make it work - I am going by the conversion info I have found on the web. Maybe Pingel has made upgrades to the adaptor? Yeah; it's a good thing your on the other site of the pound - just in case my tank explosion is epic (I hope not)
My EFI tank has a threaded hole where the tap goes, but it is too large a thread for the tap, so the adapter I have is rather like a bolt that is also threaded through the centre. The adapter screws into the tank and the tap screws into the adapter. The blank I have, which came as part of the adapter kit, has the same thread as the adapter and fits the same hole, but doesn't have a hole in it for the tap.
This link shows the adapter installed on an EFI tank (go to 'Accessories', then 'Magneti Conversion') and I can't see where you will need to do any cutting! I will be hiding down in the basement until you give the all-clear....
I think exhaust gas from an old Ironhead would work better than some Japanese car with a catalytic converter.....
