Electrical problem?
Old May 20, 2014 | 09:43 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by 1996FXDSconv
Checked bike based on grbrowns suggestions...when I turned on the ignition with out starting, everything worked. Started bike let it run for awhile, everything worked for a short time then stopped (headlights continued to stay on). Oh, the battery is brand new 500cca battery. So from what i'm reading, its probably the stator? So my next question, is this a job that's easy for someone with a little mechanical experience?
Again, thanks for any help I can get on this
Before you just decide it is the stator grab a multi meter and run through Dr Hess's sticky about checking your charging system.
It is much less expensive to do the checks and find out what is wrong than guessing and throwing parts at the problem.
Old May 20, 2014 | 02:19 PM
1996FXDSconv's Avatar
1996FXDSconv
Great advice...Ill do that this weekend and see where it leads
Old May 20, 2014 | 08:13 PM
3408pete's Avatar
3408pete
I have a box of switches that have done odd things on my old wide glide. The last one is acting up and since its wired to not have a day time running light and a separate postiton for lights it will kill the engine momentarily when switching the positions. Others have lost lights after everything has ran for time to build a little heat in the switch
Old Jun 2, 2014 | 01:05 PM
1996FXDSconv
For what it's worth...followed all the great advice and found I had a faulty ground wire...replaced it...good as new! Glad I didn't pull the stator! Thanks for all the advice!
Jacob.c.gilpin
Feb 10, 2025 08:13 PM
David Knettle
Electrical/Lighting/Alarm
Apr 7, 2019 11:45 PM
kris0082
Jan 20, 2014 02:34 PM
M&P340
Apr 29, 2012 05:55 PM
