If any of you share my distrust of Inner Primary Races, how they can walk about on the mainshaft and are a pain to set to the correct place on the shaft then you should look into fitting the S&S inner primary race next time you have the primary apart.
I have fitted a few recently and they are a wondrous thing. Easy to fit and they stay put.
Looks good, I did the All ***** 1 piece bearing that is wider and liked that set up. Getting harder to to use a stock setup with the advanced bearing being offered that won't walk into the trans seal
Dang man, I'd need a SCRAPER to remove the DIRT I SEE ON THAT THING.
S&S inner primary race...$51.99 just for the race...sealed inner primary bearing(can't walk) 13.99...both prices from J&P... I think I will pass.
There have been instances where the sealed one-piece bearing tightens up once installed and eats itself.
This is why I decided to go the S&S route as its a really nice piece of engineering... BTW we pay 95 bucks for them here and I am still really happy with it.
