Headlight acting weird
Old Jun 3, 2014 | 03:27 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by jimbo285
Does it stay steady if you idle up or add throttle?
No.....
Old Jun 3, 2014 | 03:44 PM
92Fatty's Avatar
92Fatty
I know if my ignition switch isn't just right it lights will flicker.
Old Jun 3, 2014 | 03:49 PM
Spanners39's Avatar
Spanners39
You might wanna pull the connector block on the back of the head light, the one that actually fits to the headlight. They get loose and spark and then melt the ground terminal.
That and slap your light switch during the flickering. Its behaving like a loose contact.
Old Jun 3, 2014 | 03:54 PM
texashillcountry
Dirt don't hurt
Mine too but it did it to all the lights not just the head light.
Like I said it is very weird.
Right now my best guess is that there is a loose connection inside the sealed beam headlight that makes a good connection when it gets hot.
I fully intend on going through all connections and grounds the next time I take her apart.
Old Jun 3, 2014 | 03:57 PM
texashillcountry
Dirt don't hurt
If it was that wouldn't it kill the headlight all together?
Old Jun 3, 2014 | 04:03 PM
Spanners39's Avatar
Spanners39
Nah, they flicker just like that as it makes an on-off-on-off connection with the vibration.
Old Jun 3, 2014 | 04:13 PM
Frostbite's Avatar
Frostbite
Just guessing:
You have a broken wire that barely connects when cold?
Engine warms up, wire expands and makes better connection?
Stick bike in meat locker overnight and see if lamp lights at all tomorrow morning.
Old Jun 3, 2014 | 04:37 PM
texashillcountry
Dirt don't hurt
Originally Posted by Frostbite
Just guessing:
I would if I could.
texashillcountry
Dirt don't hurt
That part I get but why only when it is cold?
Old Jun 3, 2014 | 05:05 PM
Uncle G.'s Avatar
Uncle G.
I would agree with both of these if it was doing it all the time but it only does it on first start up.
It stays on the rest of the day with no problems.
My first thought was a bad ground but that doesn't make sense either.
If it were any of the above it would do it all the time and that is not what is happening.
That's the odd thing. Mine would only act up when the bike was first started, too. Never DURING a ride. In any case, it's something to check and costs nothing but a bit of time.
I didn't think it would fix my bike either, for the same reason, but it did. Sometimes logic doesn't seem to apply when hunting electrical gremlins in a Harley.
