update Dyna 2ki / Ultima ignition
Old Jul 4, 2014 | 02:35 PM
aces&8s's Avatar
aces&8s
Default update Dyna 2ki / Ultima ignition
I finally got my Ultima / Dyna 2Ki adj ignition set to perfection and wanted to share what worked for me, knowing some of you have recently installed one.
Problem: I had lite pinging in this 90* heat when I would bog it out the hole, [first gear take off]. Retarding the ignition did not help, 4th curve did not help, high octane did not help.. ETC did not help....................
Simple fix....... THROW AWAY THE VOES....... Use the Ignition advance only and I re-dynamic tuned it to dot dead center at 1700 rpm. Im set in the 3rd curve.
Now, I Cant make it ping if I try and bike will throw you off if your not ready for lift off { T minus 1 and counting }.
Happy Independence Day
Old Jul 4, 2014 | 04:25 PM
HarDlife's Avatar
HarDlife
Glad you finally got her dialed in, ace!
When I eventually get around to getting one on mine I'll be sure to pick your brain!
Old Jul 4, 2014 | 07:15 PM
Beemervet's Avatar
Beemervet
Well now that just runs contrary to what others have said........
eeny meeny miney moe.........
Old Jul 4, 2014 | 07:37 PM
johnjzjz's Avatar
johnjzjz
and the next time he removes the head - OH NO LOOK WHAT HAPPENED --
because you Think you cant hear the ping WELL i guess its not happening
Old Jul 4, 2014 | 08:35 PM
aces&8s's Avatar
aces&8s
Never heard of a "silent Ping" but the ping I did hear is now gone. Ill take no ping over a Ping I can hear any day.
Old Jul 4, 2014 | 08:48 PM
aces&8s's Avatar
aces&8s
You mean like Curly, Larry & Moe? I can name 3 mechanics on this forum that say ditch the VOES but I wont drag them into the conversation, maybe they will chime in.
I tried everything even calling Dynatek Service a couple of times for tuning pointers with the Voes to no avail.... Dynatek said if removing the Voes works, then so do it. I reported back to Dyna Service Rep and he was proud it worked and had no other warnings..
Old Jul 4, 2014 | 08:57 PM
aces&8s's Avatar
aces&8s
Glad to help anytime, Im not the pro but I know what worked for me. This is the first time my timing has been on dead center and no ping. The adj ignition did just that all by its self. So I would conclude The advance-retared in the Adjustable ignition is quite sufficient for a proper tune with no ping.
Old Jul 5, 2014 | 06:20 AM
GraemeR's Avatar
GraemeR
I run the same Ignition and do not have the VOES connected either. I just programmed up a custom advance curve on the laptop and run with that.
Old Jul 5, 2014 | 09:39 AM
aces&8s's Avatar
aces&8s
GraemeR, Can I ask what Compression and which curve you are set at?
Old Jul 5, 2014 | 10:15 AM
junglejoe's Avatar
junglejoe
Hmmmmm.. interesting!
