Another timing question....
Old Jul 22, 2014 | 08:50 PM
HGM's Avatar
HGM
Originally Posted by aces&8s
HGM by the first set's of picture you posted, I still read it as 2 dots is international in both sets of pictures. Pretty sure you want 1 dot.
I'm not too proud to be wrong, but please take another look at the first pic.. The bottom graphic with the two dots, doesn't it say '95 HDI(injected) and '96-98 Domestic??
Old Jul 22, 2014 | 08:54 PM
HGM's Avatar
HGM
Originally Posted by texashillcountry
Ok disregard this post as I am an idiot!!!!!!!!!!!!!!!
Single dot is 35* and double dot is 20*
Use the single dot.
Hahaha, you feel my pain??
Old Jul 22, 2014 | 09:00 PM
aces&8s's Avatar
aces&8s
HDI is, HD International and the domestic it's talking about is Californication... Same as International...
Old Jul 22, 2014 | 09:13 PM
HGM's Avatar
HGM
Hmmm, I guess it must be then.. This isn't the engine from this bike.. All I really know is it came off an injected '98 RK.. I didn't make any changes tonight, just double checking things since it seemed to contradict your results.. Figure I'll roll with it with the double dots @35* and the VOES disconnected tomorrow, see how it runs.. I'm not expecting quite the results you got since its not built quite as hot, but It did run good last night.. I'll let you know either way.. Thanks for all the input guys..
Old Jul 22, 2014 | 09:30 PM
aces&8s's Avatar
aces&8s
2 dots will put you at 20*. 1 dot will give you 35* and much better performance. Your ignition is factory set about 33* or 34* to be compatible with 1 dot 35*. Hope this helps.
Old Jul 22, 2014 | 09:44 PM
Pinetop's Avatar
Pinetop
This engine shouldn't be international. If I use the single dot, I'm thinking I'd be
adding another 30* to my
current set up. I'm not
doubting you Pine, just
having a difficult time
believing that's right on this
particular engine..
american domestic not F66ked up Cali
I assumed it was stock my bad dude.
Old Jul 22, 2014 | 09:51 PM
HGM's Avatar
HGM
I actually planned on riding it tomorrow anyhow, so I ran out of time to mess with it.. I may play with it this weekend to see what the one dot does. I couldn't imagine it being that far off, but maybe it is.. Its hard to conceive me having the only one that uses two dots..
Old Jul 22, 2014 | 09:54 PM
HGM's Avatar
HGM
Its all good, might still be me..
Old Jul 23, 2014 | 09:12 AM
D_gyver's Avatar
D_gyver
if you want to get it perfect there are 2 ways to do it with that ignition.
first way is you have to use a dial back timing light. set it to 34* ground the voes and use curve 1 and use the TDC mark for timing. after its timed set the curve back to 2 or 3.
second way use usb adapter hook it up to the ignition. tach wire and voes wire. open curvemaker program set the curve 1 map to max out at 35* save and reboot the ignition. now set ignition to curve 1 ground the voes and use a regular timing light and time it to the one dot mark 35* after its timed put it back on curve 2 or 3
if all your doing is static timing it will be off about 10*-15*. static timing is just to get you close so you can start the bike. you can run the bike there and it will run cooler and have less ping and it will start easier when hot. but fuel mileage and power will suffer.
Old Jul 23, 2014 | 10:17 AM
aces&8s's Avatar
aces&8s
Thanks Mr D gyver, Very nicely stated, That needs to be a sticky.
