Does this gasket look ok
I just used my hands. Wasnt easy...however, I have to redo it haha. Had a pain in the *** getting the headers on and messed one of them up.
Any recommendations on getting the gasket in properly and easier than the dealer saying to freeze it?
It looks to me from your pic your using a oem like HD tapered header gasket. My own preference is the high performance SE or like, square edged header gasket especially with new pipes. The tapered gaskets can crush out slightly interrupting exhaust flow. The SE gasket will not. Don't have the part number in front of me. Install is simple. The SE just pushes in with your fingers.
After f*** one set up trying to put them in by hand, went to my small parts boxes to see what I could find.
Found a 2 inch diameter washer, 6 inch threaded lamp rod, secured the washer on the end of the lamp rod with a nut on each side (they came with the rod) and used that like a seal installer.
Just gently applied even pressure while wiggling it a bit and they went right in.
(BTW, as suggested by many on the forum, I froze all 4 gaskets before attempting to install them)
