2014 FXSB exhaust valve delete?
Henry Porter (06-19-2019)
On European models they are fitted with an "active exhaust valve" to reduce noise emissions.
Basically a a flap in the exhaust that is controlled by the ecu to open and close to reduce noise.
When you you fit an aftermarket exhaust system it is removed but then the ecu detects it is no longer connected and can bring up a fault code
I don't know what the solution is (maybe someone here can help), but just unplug it. If there's no fault code then you're fine. If there is one, you can try clearing it and if that doesn't work, either ignore it or not install the new exhaust. You can still ride the bike with a code.
kjr2492
03-29-2011 10:23 AM
