Sponsored by: Jekill and Hyde
Which gasket oem or se?
Old 02-12-2018, 05:39 PM
Ausreed93's Avatar
Ausreed93
Ausreed93 is offline
Default Which gasket oem or se?
Just about to install my exhaust but I'm getting mixed reviews on which gasket to go for. The exhaust is squared not tapered but some posts on this forum say to still use the tapered oem gasket instead of the screaming eagle because the se gaskets are prone to leaking. But wouldn't a square exhaust on a tapered gasket leak anyways?
Old 02-13-2018, 07:33 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
I use SE square on square exhausts. Sometimes 2 if the pipe goes too far into the head. I use the tapered gaskets (OE) on tapered head pipes. The OE tapered gaskets will work but sometimes get mushed with a square head pipe and intrude upon the exhaust port.
Old 02-13-2018, 12:07 PM
GregGillette's Avatar
GregGillette
GregGillette is offline
Recently installed the Cobra Power Port header and it seemed to be a bit more squared. I went with the SE gaskets and no leaks yet. First time removing stock gasket, installing new and it was a little unnerving as didnt want any material to break off into head, all worked out fine. Really had to tug on the oem cone gasket to get it to let go.
jlasoftail
07-04-2021 12:03 PM
mndelrosario
09-23-2016 01:31 PM
scoot883L
03-02-2016 03:58 PM
WestTexasRanger
02-21-2013 04:13 PM
marinepilot81
07-17-2010 02:53 PM
Quick Reply: Which gasket oem or se?
