Sponsored by: Jekill and Hyde
Thunder Torque Inserts test results...?
Old 04-30-2018, 05:22 PM
T^2's Avatar
T^2
T^2 is online now
Received 1,157 Likes on 724 Posts
Default Thunder Torque Inserts test results...?
Anybody seen any independent test results on these?
I've seen some before/after dyno results on bolts and lollipops, but haven't seen anything done independently on TTI's. Just curious if there was anything out there.
Old 05-01-2018, 01:11 PM
T^2's Avatar
T^2
T^2 is online now
Nobody out there has any dyno data on TTI's?
Old 05-01-2018, 01:46 PM
bustert's Avatar
bustert
bustert is offline
are you talking about torque cones that fit the header pipe? or some other type of gizmo?
if you are talking the header insert, they are largely hit/miss with emphasis on miss. they have a very small sweet spot where they actually work, the so called theory is to reduce reversion. they make a POOR band-aide for a needed well thought out exh sys.
Zappafranck (08-25-2020)
Old 05-01-2018, 02:29 PM
DK Custom - ST's Avatar
DK Custom - ST
DK Custom - ST is offline
Platinum Sponsor
Here's a dyno to give you an idea-
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old 05-01-2018, 04:34 PM
T^2's Avatar
T^2
T^2 is online now
Appreciate that...
However, I was hoping to see a larger body of evidence (engine models/exhaust combinations etc.) than what's available on your website. Plus it would be interesting to see what folks are experiencing (actual real data, not anecdotal evidence/baseless opinion) out in the field so to speak.
I haven't looked at the details of TTI installation. Drill holes in pipes presumably... What does one do with the holes, should one conclude that the TTI impact is a net negative and decide to remove them?
Old 11-09-2018, 11:25 AM
chasu99's Avatar
chasu99
chasu99 is offline
Many articles on adjustable baffles (lollipops) on the internet. That dip in torque around 2000-3000 is eliminated with TTI or just about any well fabricated lollipop. Backpressure that is removed from the exhaust system causes the dip in torque, but adding a little managed backpressure makes the engine happier at mid-low RPM. Lots of data out there. Drilling a hole on the "out of site" location on the pipe or tip is a very small price to pay for the performance they bring to the table. If you don't like them for some reason, all you have to do is fill it with a small pan head screw and a nut on the inside. I doubt you'll not like the performance they add to bikes that have had the baffles removed.
Old 03-23-2019, 03:54 PM
Livewire77's Avatar
Livewire77
Livewire77 is offline
I know this is an older thread but just thought I would add on the drilling of pipes. I was able to pull my baffle. Drill the baffle and install tti. Then just reinstalled the baffle with no damage to the outer portion of the slip-on. As far as torque oh ya they help. I never did a pull before the tti but as soon as I bolted them in it was a lot more responsive down low. When I did Dyno later on majority of my torque is from 2250 to 4000 with true duals. I decided to try them and it was the best decision I made. Wish I had a before Dyno pull best I can say is I ran live torque data on the fp3 and saw the torque change just over 10 ft-lbs after the install. It definitely felt better.
Old 10-08-2019, 02:59 PM
MoparBob's Avatar
MoparBob
MoparBob is offline
Anyone know if these can be installed in the collector before the muffler?
Old 01-21-2024, 08:35 AM
Weeboy1's Avatar
Weeboy1
Weeboy1 is offline
yes I know this is an old thread!….just wondering if you still have this setup and any pics to share. I’m considering this on my MGS slip ons and can likely do the same as you. Just wondering where you installed the tti’s.
this is a pic of my idea…
Old 01-21-2024, 08:47 AM
Weeboy1's Avatar
Weeboy1
Weeboy1 is offline
Any others thoughts and opinions are welcome. Considering the DK customs tti’s. This is more of an experiment to see if there’s improvement with the inserts. Planning to eventually change mufflers to 4.5” anyway.
Quick Reply: Thunder Torque Inserts test results...?
