'04 Softail Standard--smell gas
RE: '04 Softail Standard--smell gas
If you don't turn off the fuel valve, you might try turning it off with the engine running about a minute before you pull into the garage. There is a possibility the fuel valve is sticking open allowing seepage into the carb / crankcase. Other than that, I'd be out of ideas.
electra glide
Exhaust System Topics
10-18-2009 10:06 AM
