I have an 06 Road King Custom and recently put the Vance and Hines Big Shot Duals, Big Sucker air cleaner and SERT and had it Dyno Tuned. If I were to change out the baffles, for example, Quiet Baffles or Thunder Monsters would I have to redo the Dyno tuning? Thanks.
I believe you would at the least, have to have it re-tuned using your SERT.
Question for you... do you like the setup? Sound and performance? Did you loose anything on the low end.
I have the same bike and haven't modified anything yet, but I am still looking.
Pipe back pressure is going to play into your fuel curve. You would not know how much it changed it until you make the swap and then make a pull on the dyno with a Air Fuel Ratio moniter and look at the fuel curve, as well as checking fuel curve in the cruise range as well. Sometimes it will make a large change in a small area and others little at all, The engine is a air pump so alter air in or out will effect amount of fuel that you are currently using
