What did I screw up? Just changed rocker gaskets on my 1340 evo
I just changed the rocker gaskets on my 96 FXSTC, it already had adj push rods, I also changed the push rod gaskets. I fired it up, runs great, after letting it warm up , went for a ride, oil leaking heavily from top of push rods both sides. I can see maybe one push rod cover leaking but not both sides. I had to shut her down, I inspected the upper orings and they were fine. Could there be a problem with the black valves I replaced in the middle cover? \\; I don't know what elso it could be, I used a quality gasket set, no other leaks. Any help appreciated.[>:]
RE: What did I screw up? Just changed rocker gaskets on my 1340 evo
Did you just change the upper gasket, or both upper and Lower???
If you changed the lower, did you verify the orientation of the gasket..... Front on front and Rear on rear.....
Are the pushrod tubes bottommed out correctly into the o-rings in the heads????
Also... Please take a moment and introduce yourself in the NEW MEMBERS SECTION at your earliest.....
Shovelhead Bob, I think you nailed it, my DA didn't even look closely at the gaskets, I bet they are on backwards causing \\; blowby at the top of the pushrods. Thanks so much for your help, I'm going to go kick my *** for a minute and then beg the wife for more time to fix it. BTW, I did a little intro in the new mwmber section. Thanks a lot, Jaybird
Follow up. \\; I did put the gaskets on correctly the first time, in fact, after looking at them, you would have to be more than a complete moron to put them on backwards. I didn't have the push rods adjusted correctly, BTW, if anyone lives in central Illinois (Champaign), check out Midstate cycles for quality, friendly service/parts.
