Removing SE Slip on baffles.
I have had just about enough of my slip ons. I have an 06 RK Classic, with SE Slip ons. I have purchased a race tuner, but was waiting to get V&\\;H exhaust before I put it on. I have run out of money, and cannot buy pipes.
So, my question is, will it damage the bike any by installing the SE \\;Race Tuner and taking out the baffles? Are there any other CHEAP suggestions?
Thanks!
Thanks!
RE: Removing SE Slip on baffles.
Steve, do you happen to know which SE slip ons you have? \\;
What don't you like \\;about them? \\; \\;
If they happen to be the 65115-98B's you can not remove the baffles in the typical sense. \\; They are in a canister that does not allow you to access the baffles. \\;But you can remove the entire canister leaving the shell of the muffler. \\;  \\;
If they are these mufflers you can check with SuperTrapp as they might have freer flowing canisters you can purchase. \\;
Also, if they happen to be 65115-98B's I would put them for sale on this website. \\; They are a very sought after item. \\;
Thanks for your reply.The performance of these are fine, however I want a louder sound. Just a little too quiet for me. \\\\\\;I would be honest in saying I am not sure which model they are. I bought them over 2 years ago, and would have to look it up. However, they are the ones with the canister that has the baffles inside. I have pull them completely out and now have a hollow shell. I have not taken it out on the road to test it. Wanted to see if there would be a problem first. I know it will take the back pressure away, and hurt the performance a bit...but wasn't sure about what it might do to the bike overall. I will also take a look at the supertrapp idea.
