reduce compression
Old Oct 24, 2008 | 10:00 PM
gpp's Avatar
gpp
Default reduce compression
i have a set of se heads for my 103 build that yeild about 10.80 compression according to the harley chart.how can i get it down to about 10.01?
Old Oct 25, 2008 | 12:06 AM
new_mentor70's Avatar
new_mentor70
well, you can do a couple of things, first off are you running flat top pistons, or domed pistons?
you can swith either one out for a dished piston and recalculate. or as i recently did, have a domed piston milled down a few CCs to correct the compression.
If you have a lighter bike, like a Dyna and 93 oct. fuel or your at high alitude, over 3500 ft above sea level you could do a cam swap and or ignition work and you may get by with that kind of cylinder presure.
I have a 10.2 to 1 HQ build and im at sea level, but I also have a 10.8 setup for my bike (bigger domed pistons) if I ever move back to Utah, which is 4000 ft in my home town! using the same cams and ignition I have now will run just like it dose down here in LA.
you may want to consult and Indy, hand him your heads and get them CCed to see where they realy are and see what your options realy are.
cike
Engine Mechanical Topics
Mar 6, 2014 12:00 PM
75hdxlh1000
Ironhead
Aug 28, 2012 09:37 AM
Sadthorn
18
Jan 22, 2011 08:15 AM
Night Hog
Feb 5, 2010 02:09 PM
WEBBiker
Nov 7, 2006 02:11 AM
