carb problem
Old Mar 22, 2009 | 04:31 PM
mikewatts's Avatar
mikewatts
6th Gear
Default carb problem
hi just looking for some info.. got a 05 softail twin cam 88. when im running under 30 mph and at idle the carb makes a popping sound and shuts the engine off. it happens on almost every trip. dont know what to look for.... it has 6000 miles on it???? slip on screamn eagles
Old Mar 22, 2009 | 04:34 PM
esyrdgcwby's Avatar
esyrdgcwby
Need some more info
Do you have an air cleaner on it ?
Have you messed around with the carb? taken it apart, etc.
Has it done this since you bought the bike or only after you have made a change?
Old Mar 22, 2009 | 04:43 PM
mikewatts's Avatar
mikewatts
6th Gear
I baught the bike last year and it did it from day one.. it has a cleaner and about 6500 miles on it. i baught it used with 2000 miles on it...not sure what it could be... im new with harley since riding triumph
Old Mar 22, 2009 | 07:45 PM
Tltrump's Avatar
Tltrump
Default you need a bigger slow jet
check needle position and slow jet size
Old Mar 22, 2009 | 08:53 PM
mtclassic's Avatar
mtclassic
also possible it has an air leak causing a lean condition. the air leaks are usually were the carb goes on the manifold or where the manifold bolts to the heads. some times the rubber gaskets can get pinched or dislodged keeping them from sealing.
Old Mar 23, 2009 | 04:46 PM
mikewatts's Avatar
mikewatts
6th Gear
thanks alot man, i'm gona check that out myself as soon as i can!!! il let you know if it works... appreciate the help
Old Mar 23, 2009 | 04:48 PM
esyrdgcwby's Avatar
esyrdgcwby
Most likely the carb, needs to be rejeted, I would bump up both the slow & main jet one size. also make sure all your vacum line are intact.
Old Mar 23, 2009 | 05:45 PM
mikewatts's Avatar
mikewatts
6th Gear
thanks easy rider man, im gona check that out before the snow melts, hopefully getr runnin' 100... il let you know... appreciate the info!!!
blackbear
EVO
37
Oct 13, 2012 06:02 PM
dragonfire1970
EVO
21
May 7, 2010 06:16 PM
aeproberts
Mar 12, 2009 02:45 PM
Slanter
Jul 31, 2006 01:02 AM
