Modified Thunder Headers
Old Nov 27, 2009 | 01:11 PM
Bad Disposition's Avatar
Bad Disposition
Default Modified Thunder Headers
I was looking at a couple of old posts, came across a comment about modifying a Thunder Header. What are the pros and cons? How is it done? After it's done, does the mod cause a re-tune (DYNO)? last but not least is it worth the time and effort?
Old Nov 27, 2009 | 06:26 PM
SEDELUXE's Avatar
SEDELUXE
imo the theader is a great put it on and tune the bike... any time you alter the air flow in or out the afr should be checked. just to be safe.
Old Nov 27, 2009 | 08:50 PM
maineultraclassic's Avatar
maineultraclassic
It's a simple mod that doesn't require any AFR tuning after it's done.
What you are modifying is the rear most part of the baffle. If you look into the muffler from the rear, you will see a square made out of metal. What you do is take a long socket extension or steel bar and bend 3 of the 4 sides of that square out towards the round sides until it is about 1/8" away. What that will do is create a bit more back pressure and take care of the low-end torque dip the TH is known to have.
I did it to both of my TH exhausts when I had them, and to a couple of friends as well.
Steve
Old Nov 27, 2009 | 09:01 PM
Bad Disposition
Thank you George and Steve, as always I appriciate the help.
Ceciliozrt@gmail.com
Jun 21, 2016 06:51 AM
Candy Red Road Glide
Dec 6, 2012 11:10 AM
KeeBee
Apr 10, 2011 10:39 AM
flip180
Apr 3, 2010 10:45 AM
CaptnAl
Jul 26, 2005 09:42 AM
