Oil blowing out of breather
I have a 2002 Ultra which I just changed the lifters, installed adjustable pushrods and changed the rockers. After running the engine for a couple of minutes, I begin to get oil coming out the rear breather, The breather has a new filter, O ring and gaskets. Upon further review, I found a small obstruction on the inlet valve drain channel, which I am not sure if it was big enough to prevent all the oil from draining through the port. This piece was half round and brittle, and probably a good 1/4" tall, which I thought it might be a piece of locktite, but now I question that decision, and wonder if it might be part of the valve stem seal. Is there anything that could be responsible for this oil problem?
Thanks, Charlie
After further evaluation, I could not find any blockage, ran plastic tie wrap all the way down to the crank case through the drain hole. Oil is still coming out the breather screw hole. I do seem to have more pressure coming out from this cylinder's breather screw hole than the front cylinder. Any suggestions would be greatly appreciated.
Thanks, Charlie
You probably found it.
You can also enlarge those holes to .125", to get the oil away from that area better.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
travistodd1
Exhaust System Topics
01-10-2014 11:26 AM
