Sponsored by: Jekill and Hyde
Crank Run-Out Who has checked prior to cam swap?
Old 09-29-2011, 06:08 PM
klaybus's Avatar
klaybus
klaybus is offline
Default Crank Run-Out Who has checked prior to cam swap?
Been following a thread from HDF member "Swaite" in regards to his crank run-out being outta spec & am curious how many people actually checked the run-out prior to doing a cam swap...
Old 09-29-2011, 06:36 PM
mrlexus's Avatar
mrlexus
mrlexus is offline
I did. If you thinking about gear drive, you must check it.
Old 09-29-2011, 06:43 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
I didn't check, went with chain drive. If you don't wanna know the answer, don't ask the question!!
Old 09-29-2011, 06:52 PM
Race freak's Avatar
Race freak
Race freak is offline
Can the runout be done properly without having to remove the cam chest, just the outside cover itself?
Old 09-29-2011, 07:39 PM
FBFletch's Avatar
FBFletch
FBFletch is offline
With my recent engine modifications, the engine builder (fortunately) checked the crank runout before ordering my gear drive cams. Mine was right at the limit which, if I recall correctly, is .030". Someone please correct me if that's wrong.
Anyway, my engine builder flatly refuses to install gear drive cams if the crank runout exceeds the limit.
Old 09-29-2011, 08:02 PM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
I checked mine and a friends both were .003
Old 09-29-2011, 08:11 PM
klaybus's Avatar
klaybus
klaybus is offline
What is used to check the run-out? I'm thinking before I put cams in I will wanna borrow or maybe rent the necessary tool to do this. Name & or possible model # of said tool?
Old 09-29-2011, 08:16 PM
djl's Avatar
djl
djl is online now
Received 2,102 Likes on 1,544 Posts
.003" is the generally acceptable limit for gear drive cams.
Old 09-29-2011, 08:21 PM
djl's Avatar
djl
djl is online now
A dial indicator securely mounted somewhere (most use a magnetic base) so that it won't move when the crank is rotated. Check with cam plate removed. Check every 90*; you are measuring total runout.
Google crank runout and look for a YouTube video. I believe Randy (King of Cubes) has one on his website. Harley Hog had a video on his website but I believe the MoCo finally forced him to take the site down.
Old 09-29-2011, 08:24 PM
FBFletch's Avatar
FBFletch
FBFletch is offline
Thanks. I missed a decimel place.
Quick Reply: Crank Run-Out Who has checked prior to cam swap?
