Splutter and stop
Hi Guys
I have a HD Dyna fat bob stage 1 with shortshots and a screaming eagle download.
It was running perfect on December when I put her away. I took the tank and exhausts and bars off to be painted/powder coated, put it all back together. Now it starts runs ok then when choke cuts out it coughs through the air filter and stops. If you rev it it runs on one cylinder. We have removed and replaced fuel filters, changed plugs, leads and coil. Checked exhaust for leaks and changed out the cam sensor.
Now at a loose end can anyone help??
Cheers
Cheers
