Engine dies at idle when hot ('01 Road King Classic)
I posted this in the general Touring forum yesterday, but I think it might belong here instead:
I bought an '01 Road King Classic on Friday and trailered it home from the dealership. The test ride at the dealership went fine, but yesterday was my first chance for a longer ride. After about 30 minutes, I had to stop for a light. The engine started idling rough, then died. It would not restart until I cycled the ignition off and back on again. I decided to head home and had to stop twice more on the way. Both times I had to open the throttle a little bit to keep the engine running. When I got home I let it idle in the driveway and it died again. It seems to idle fine when cold, so I'm hoping the hot idle just needs an adjustment. However, I don't understand the need to cycle the ignition to get it to restart. I know that causes the fuel pump to repressurize on these fuel injected engines. Could I have a bad fuel pump? Any help would be greatly appreciated.
The dealership I bought it from is 2.5 hours away, so taking it back over there is not a great option. However, I'm going to call the salesperson tomorrow to see what she has to say about it.
Yep, I've found several posts on the subject now. One indicating that owners of a bike with the MM EFI should get familiar with the idle speed adjustment process. I've already got a service manual on order. There is also a sticky on one of these threads that details the adjustment process for both cold and hot idle. Unfortunately, no pictures, which is why I order the manual.
When my 01 Ultra does that, I take a/c off and clean the air bleeds inside the intake. They are at the 2 and 10 o'clock with MAP sensor cleaner. Stick nozzle in each hole and cycle on ignition, wait a few seconds and repeat til clean. I stick a rag inside, next to the butterflies, as it doesn't like to run right for a few minutes if it get into intake. 51000 miles so far with no problems.
I would be interested in knowing what you're using as MAP sensor cleaner. A quick Google search shows some people are using brake cleaner, some are using carb cleaner, and others recommend a low-residue cleaner such as electrical parts cleaner. There doesn't appear to be a product made specifically to clean MAP sensors.
. correction.....that would be MAF sensor,,,MASS AIR FLOW-- located in the air duct normally between the filter and TB>>looks like a little resistor....Available at most parts stores, Bumper TO Bumper/ autozone, O'Reily.......I usually use carb cleaner,,,they also make a spary cleaner for a Throttle Body. I've used that on my Trailblazer......
Calvin1989
10-03-2013 10:00 AM
