Help with piston?
Help with piston?
Purchased a 81 flt shovel and doing restoration. Tore down engine 80 cu. In. and had the jugs miced. The guy td me the jugs were honed out 30 over but the lower part of the jugs were only 20 over. The pistons were badly scored so I want to order new ones 30 over. Don't know if they are 8.5-1 or 9.5-1.How do you tell the difference? The pistons are labeled Bohnalite # 22124-78 and show 030 on the top of the piston. Any help would be appreciated.
Ben
Ben
22124-78 is a Harley part number, so they are most likely stock compression. Unlikely to be 9.5:1 IMHO. Bohnalite is the manufacturer and if you google that name you can learn more about them!
Before you order any new pistons find someone who can true up your cylinders, so they are a uniform size top to bottom. If that means going to the next size up, then +.030 pistons will be a waste of money! Don't get your cylinders honed until you have new pistons in hand, so the two are married accurately to each other.
Maybe just common use of interchangeability of words but you do not want to have someone just hone your cylinders to fit. They need to be carefully measure and could be as bad as you describe them even rough bored to see where they are going to clean up before finial honing and crosshatch finish for proper clearance to piston. Whatever you do make sure the shop is going to bore them to make them round and true top to bottom with them bolted into torque plates.
Ben
Ben
If your looking for help, we can certainly provide it.
Feel free to contact us.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I realize that you don't hone out cylinders,but the previous owner didn't. The cylinders walls are not scored, only the piston skirts
