Where to get rocker shaft shims???
Alan rocker have end play side to side, so if there may be to much the bike will clatter with them moving back and fourth. So you just pull the rocker shaft out and you place the shim in to make up the space. I got the roller rockers used so the guy before probably ran them hard and the end play it a little more than I like.
One needs .010" and the others might just need .005"
http://www.zippersperformance.com/rocker-arm-shims.html
Yah I say zipper has those but they only offer .007" and .015".
Just spoke to Kirby, so I don't think mine are bad at all. I will recheck them when I get home, but I rather have it be a bit louder than run a risk of a shim floating around my motor.
If mine really get out of wack I'm sending them over to Kirby to counter bore them and get them fit with the .100" shims.
To those looking for shims here is the place:
http://www.mcmaster.com/#standard-shims/=q9igom
Gazzalodi
08-27-2018 09:12 PM
