Dumb question of the day...
What is the thread size for the screws that hold the cam cover to a 1937-1948 engine case ?
I’ve tried 1/4-20 and 1/4-28 and neither fit.
Cam cover - lifter blocks - distributor screws and voltage regulator mount - trans mission top cover - i might have forgotten one or 2 — 1/4 X 24 its a special thread colony products carries everything for the early machines
The cases are Cannonball reproduction out of Germany, they wrote me back and said that the threads are 1/4”-24 and suggested
the Colony, I have brand new set of Colony 8149-12 but they are slightly too big, the Colony package doesn’t say that they are 1/4”-24 but rather they fit 1936-1969 big twin.
Do you happen to have the Colony part number for the 1/4”-24 ? I couldn’t find one in the Colony catalog.
Problem solved.
It looks like Cannonball does their bead blasting after all the holes are tapped and are a little rough.
I didn’t want to force the Colony cam cover screws into the holes because the package didn’t say they were “1/4”-24” only that they fit 1936-1969 big twin and they didn’t feel right to me.
I ordered a 1/4”-24 tap which came today and it matched the Colony screws, I chucked it up in a old drill chuck I had laying around and it cleaned the holes up easily with a little oil by hand, it took almost no effort so I knew I wasn’t cutting a new thread.
The Colony screws fit perfectly now.
I’m just farting around doing a little test fitting on the engine parts I can’t fully get started until I finish the 31 hot rod I’m building.
Here’s a question for John or anyone else who has an opinion.
The tappet blocks are very tight and will only push in around a 1/4” or so, how tight should the fit be between the tappet block and the engine case ?
Here’s a couple pics from today.
