Brake caliper question
My bike is a 1996 fatboy. It has a single side, single piston caliper.
I purchased the bike last month. I noticed by Pistons only push out 1/4"-1/2" when I press the brake lever fully. It took me about a minute of none stop pumping on the lever to push the piston out of the caliper.
I took caliper apart, it was super clean, I changed seal anyways, I changed to fresh dot 5 and bled. And still the same .
Is this normal?
Is this normal?
Well it stops! But I am coming from a 4 piston dual rotor bike .. So I am not sure if I can judge if it's normal for the bike 😎
Well The interesting part is , the service manual calls for minimum 0.200" for the rotor, but the rotors themselves that are on the bike are stamped minimum 0.180" , I am over the minimum that is stamped on the rotor. I am at 0.189 - 0.190
As for your opening comments about piston travel, when using brakes normally the pistons only move a short distance, yours sound to be in excellent health! I'm not sure why you would want to remove them?
