98 Dyna Low Rider (dual discs) dual/double banjo bolt
Hey all,
Hoping you can help me figure this out quickly. Trying to finish up my bike for a camping trip in a few weeks. I've got a 98 Dyna Low Rider that has dual front discs.
I'm in the process of swapping to 12" apes (using the stock 2" risers) and am changing all the cables. The original front brake line setup is all one piece, with a single line from the master cylinder, to a distribution block under the triples that runs lines to each front caliper. There's no way to extend this for the new bars.
I'm building new front lines out of Goodridge Sniper 2 line and fittings. I've already built the lines. Just for reference, all 3 banjo bolts are 3/8-24 thread.
The problem is the dual banjo bolt for the master cylinder to let me run 2 separate lines from it. I purchased the Goodridge 733-03LCH from TC Bros (where I bought all the fittings from). The problem is it's about 10mm too long when the thread bottoms out in the master cylinder. The fittings don't even line up with the holes if it did thread in all the way.
Anybody had this problem before? What dual banjo bolt did you use that is shorter? See my attached pic of the Goodridge catalog, looks like I need 733-03 (not L [long] version) that is about 10mm shorter. I can't find this part number or bolt anywhere!
Any ideas?
Thanks all!
Any ideas?
Thanks all!
Hey all,
Any ideas?
Thanks all!
Any ideas?
Thanks all!
Just a heads up for anybody that has this problem. Found the correct banjo bolt at a local brake/hydraulic shop.
BrakeQuip BQ8085 banjo bolt works perfectly.
http://www.brakequipproducts.com/pro...-24-unf-double
IronStu
General Topics/Tech Tips
08-26-2015 03:00 PM
