??? Banjo
Old Feb 2, 2012 | 12:57 PM
r46jack's Avatar
r46jack
Default ??? Banjo
Anyone know the degrees of the caliper banjo on a FXDC, please.
Old Feb 2, 2012 | 01:30 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Let me kno what year & front/rear and I'll run a check for you....
Old Feb 2, 2012 | 01:35 PM
r46jack's Avatar
r46jack
cheers, im strugling now, sizes, ie 7/16, 3/8, 10 mm bore. What i do know is, 90degree on master cylinder and line length. Ive changed bars see and its brake line causing probs, 2009 FXDC.
Old Feb 2, 2012 | 02:14 PM
FXD2003Rider
Here's what I found using Ronnie's database:
Banjo bolt used on front brake caliper is 41747-82A = 10mm
Banjo bolt used on master cylinder is 41739-84A = 12 mm
Old Feb 2, 2012 | 02:22 PM
r46jack's Avatar
r46jack
thank you but ronnie aint got it right, 09 fxdc is a single disc.
Old Feb 2, 2012 | 02:24 PM
FXD2003Rider
If you check this diagram you'll see single & dual disk brake lines. Banjo bolts have same # in diagram.
Perhaps some one who has the 2009 Parts catalog could chime in....
Edit: added new link
Old Feb 2, 2012 | 02:33 PM
r46jack's Avatar
r46jack
gotcha, could just do with knowing that angle on caliper, i think 30o 35o or 45o ???
Old Feb 2, 2012 | 03:04 PM
FXD2003Rider
Cant tell you for sure. My best guess is 90 degrees at the front caliper. Best you could do is make a mock-up using a plastic hose and run it from the caliper up along the front end to the master cylinder. Using a protractor you'll be able to determine the angle at the master cylinder and caliper.
SixDD
Apr 28, 2019 02:17 PM
cycler
Dec 9, 2018 01:58 AM
rgm
Jan 23, 2013 09:58 PM
MeanBean
Ironhead
Apr 20, 2012 08:55 PM
fiveola
Shovelhead
Jun 14, 2010 02:03 PM
