Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Shovelhead in Evolution Frame
Old 06-14-2007, 04:01 PM
sawdust's Avatar
sawdust
sawdust is offline
1st Gear
Default Shovelhead in Evolution Frame
There is a nice santee frame I would like to buy, but documentation states it will only fit evolution motors and softail transmissions, and I have a shovel. I am willing to replace the tranny if need be (I have a 81' 5spd tranny) but not the shovel. From what I know (and that ain't much) there is no diffrence between the shovelhead and evolution in terms of motor mounts.
If a frame will fit an evolution, will it fit a shovel?
Thanks in advance.
Old 06-14-2007, 04:12 PM
EVOrider's Avatar
EVOrider
EVOrider is offline
Default RE: Shovelhead in Evolution Frame
I believe it will fit....but cannot gurantee it though. If your Shovel has the nose cone found on the EVO....it really ought to fit. The Shovel and EVO are very similar anyways.
The motor mounts are probably the same. The motor mounts used on the Electra Glides are the exact same ones used on the 1980 FLT. The early FXR's had the Shovelhead, that same frame housed the EVO as well with no changes in the frame.
If an EVO will fit, A Shovel should fit as well.
Old 06-14-2007, 04:58 PM
BLACKY79's Avatar
BLACKY79
BLACKY79 is offline
6th Gear
i think EVO is right; shovel in an evo will work BUT evo in a shovel will take at least 1 frame mod. the rear cylinder exhaust will not clear.
Old 06-17-2007, 11:04 AM
EVOrider's Avatar
EVOrider
EVOrider is offline
ORIGINAL: BLACKY79
I was thinking that as well. It is soooooo close....but yet so far away from fitting. Shovel in EVO frame will work fine. EVO will work in many Shovel frames....but most require a frame modifications.
Old 06-23-2007, 11:06 AM
kiwidave2's Avatar
kiwidave2
kiwidave2 is offline
It will **fit** into the frame like the guys say. But it may well be down to the mounting points....
You don't say if it is a replica softail, replica FXR or hardtail frame....
Old 06-30-2007, 04:04 PM
byersmtrco's Avatar
byersmtrco
byersmtrco is offline
Evo motor is taller. Shovel mtr will fit in place of an Evo, but not visa versa.
Joe Pritts
05-12-2016 10:31 AM
AND
Shovelhead
09-16-2014 11:43 PM
waynemags
EVO
05-27-2009 02:53 PM
fdxwizard
Custom Models
04-14-2008 02:55 AM
Eyeball Kid
Custom Models
07-15-2007 10:14 AM
Quick Reply: Shovelhead in Evolution Frame
