Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Brake Resevoir - What Causes This?
Old 11-18-2017, 12:26 PM
Paul32730's Avatar
Paul32730
Paul32730 is offline
Default Brake Resevoir - What Causes This?
I bought a 2012 Ultra Limited, 30K on the bike. Well taken care of. This bike, along with others I've had both new and used always end up with the paint around the edge of the front brake reservoir cap crinkling up. I was always very careful not to overfill and tighten correctly on my other bikes, I haven't done any brake maintenance on this one at all yet. Is this a common thing? Is there anything I can do other than buying replacement caps to fix it?
Old 11-18-2017, 12:34 PM
Hoginedgewood's Avatar
Hoginedgewood
Hoginedgewood is offline
Received 1,190 Likes on 652 Posts
Mine do it
Paul32730 (11-18-2017)
Old 11-18-2017, 12:38 PM
bad tappets's Avatar
bad tappets
bad tappets is offline
Brake fluid dissolves paint.
Old 11-18-2017, 02:47 PM
IKnowNot's Avatar
IKnowNot
IKnowNot is offline
...Is there anything I can do other than buying replacement caps to fix it?
No, common problem.
From the picture it looks like you have one that has a lip on the gasket that gets squeezed between the base and the cap. On the replacement I bought (42855-06c) the gasket fits inside the lid. Does not seem to leak like the old one.
Just be advised, the torque specs on the new cap are a lot less then the old one, don’t over tighten.
Paul32730 (11-19-2017)
Old 11-18-2017, 03:08 PM
TpaGreenHornet's Avatar
TpaGreenHornet
TpaGreenHornet is offline
They replaced mine like that under warrenty. They had a faulty seal design back in that time period. Mine is a 2011.
Old 11-19-2017, 10:07 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,499 Likes on 4,612 Posts
Many of the leakers have been over tightened.
Very little torque is needed.
Old 11-19-2017, 01:30 PM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
They all do that
Old 11-19-2017, 01:51 PM
IKnowNot's Avatar
IKnowNot
IKnowNot is offline
Many of the leakers have been over tightened ...
Could be, and that was the claim by the MoCo for years.
Mine was under tightened: the day after I had a service done I noticed some seepage and found I could turn the screws with my fingernail.
But what is the proper torque?
My manual says 7-10 inch pounds for front, I believe the 2011 manual says 8-12 for the same cap.
It was just a poor design.
AS I Recall ...
The MoCo got tired of replacing these things under warranty and told dealers that any replacements should be done using the 42855-06c kit. (Comes with new cap, new style gasket that fits completely inside of the reservoir. New style gasket must be used with new style cover.)
That cover kit became standard on the 2013 touring bikes. I believe the torque spec for the new cover is about 6 inch pounds.
Old 12-28-2017, 09:52 AM
wibiker's Avatar
wibiker
wibiker is offline
My cover started to wrinkle the first year after I bought the bike new (09 FLHTC). I believe that my dealer said it wasn't covered under warranty. After looking at it for several years I got a chrome replacement for $60, a genuine HD part made in Italy. I'll let you know when the chrome starts to peel.
sarpeezy
09-01-2014 06:21 PM
fatboy slim
04-09-2014 08:41 PM
IronBoy883
03-02-2013 12:09 PM
Ultra Dare
09-23-2011 10:40 AM
d_dog17
03-26-2007 12:36 AM
Quick Reply: Brake Resevoir - What Causes This?
