lever removal
RE: lever removal
Man, buy yourself a service manual before you really screw something up.
In the meantime, trace the clutch cable from the lever and you will find a rubber boot as the cable passes behind your front fender; slide the rubber boot down and you will see a hex sleeve and lock nut; back off the lock nut and turn the hex sleeve to create slack in the cable.
