Lever not returning fat enough
2013 Dyna Street Bob
When I release the front brake lever, the brake light stays lit until i PUSH the lever forward about 1/8 - 1/4 inch, then ithe brake light goes off.
This is scaring me because - If I drive around not realizing my brake light is already lit, there will be not change when I grab a handful of brake.
Thanks
Thanks
The following 2 users liked this post by eighteight:
07UltraGuy (05-10-2024),
Ohio HD (05-10-2024)
Received 19,838 Likes
2. When was the last time you flushed your brake fluid?
3. If you have moisture in the fluid, it will not preform as intended and may not release the lever back fully.
4. Flushing and bleeding the brake lines along with cleaning the switch as stated above should fix your issue.
NOTE:
The above information, while credible, is worth what you paid for it and should not be considered gospel.
Do due diligence, research and have a H-D Field Service Manual before working on your bike.
You will probably have many opinions and suggestions presented; make sure you research the person providing the helpful information as there are some who provide good information that is useful and some who speak out of other orifices with gibberish. You will figure out this quickly.
KISS
take a look at the cable adjustment. the return in the master only has limited travel. if your brakes seem to drag, def look at the master for sticking since the common port is not being fully open at the ned of the return stroke.
1?4 free lever play is excessive and only adds to lever buzz.
