Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Steering Bearing Race Replacement Tooling?
Old Mar 23, 2026 | 09:39 AM
twincam10353's Avatar
twincam10353
Default Steering Bearing Race Replacement Tooling?
Getting ready to rebuild the entire front end on my 2003 XL including the steering head bearings & races. I've never done this before so I just started looking into the tools that I'll need.
I've looked at a variety of options and it seems like this Motion Pro tool is the only one I can find that both removes and installs the new races. It seems like every other option is a designated tool for removal and a separate tool for installation.
https://www.motionpro.com/product/08-0633
Thoughts? Any options I'm missing here?
Old Mar 23, 2026 | 12:18 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Are you sure the bearings need to be replaced?
XL is a relatively light bike, not known for wearing out steering head bearings, actually most Big Twins are not known for this until they got super heavy (Twin Cams and M8`s).
If the bearings do need to be replaced, you are going to have to remove the inner race from the lower triple clamp also...
That will require a separate tool.
https://www.motionpro.com/product/08-0558
Old Mar 23, 2026 | 01:44 PM
twincam10353
The bike is 23 years old and I'm going to have the entire front end torn apart anyways so I'm just going to replace the bearings & the races while I'm there.
I think this was a typo on your part? Both bearing races are pressed into the neck of the frame (one on the top side and one on the bottom side).
I think you're trying to tell me that I'll need that separate tool to replace the BEARING that's pressed onto the lower portion of the stem (which is pressed into the lower tripe tree).
You are right about that, but I won't need that other tool because I plan on using my 12 ton shop press to press the stem completely out of the lower tree for powder coat. I'll then use the shop press to reinstall the steam with a new bearing on it as well.
Old Mar 23, 2026 | 02:07 PM
Dan89FLSTC's Avatar
Dan89FLSTC
In my years as a Jet Engine mechanic since the early `70s I`ve seen, removed, replaced a zillion bearings, roller type, ball type, hydrodynamic type...
FYI:
Inside the steering neck are the outer races.
On the steering stem are the inner races, rollers, and cage.
When these components are all together, they are a bearing.
But thanks for trying to school me.
Good luck.
Old Mar 23, 2026 | 02:40 PM
twincam10353
FYI:
Good luck.
You took it the wrong way, I was just looking for clarification...
Old Mar 23, 2026 | 02:51 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I wanted to clarify that each bearing assembly has two races, one in the steering neck, and one on the stem.
Maybe a bit trivial, but some reading this forum may be just starting out in the mechanic world.
When you get the bearing parts clean, take a pic for us.
Old Mar 24, 2026 | 10:35 AM
LQQK_OUT's Avatar
LQQK_OUT
I believe George's Garage is another option for Harley specific tools you may need.
Steering Head Race Remover
Driver Handle Wedge Spacer for Removing & Installing Harley® Race Bearings
Driver Handle for Race Bearing Removal and Installation
Steering Head Race Installer
Old Mar 24, 2026 | 12:32 PM
Architect's Avatar
Architect
Not an issue to change the bearings, cheap insurance. Neck races are probably fine unless something happened to damage them, even at their age. Amazon has a $20 tool for removing the races, new can go in with a proper sized socket and hammer. My local machine shop removes and installs the bearing on the fork stem for about $25.
Tool below is really all you need to remove the race, and a big hammer. I had to grind the flange down to fit my Panhead, not sure if you will need to do the same for an XL. For a one time project I see no reason to purchase a pro tool. Good luck.
Old Mar 24, 2026 | 07:45 PM
multihdrdr's Avatar
multihdrdr
Why are you pressing out the steering stem to powder coat the Lower Tree?
Btw, have you ever pressed out a stem? ... be aware of the direction for removal. People can get that wrong
Old Mar 25, 2026 | 08:47 AM
twincam10353
Are you suggesting to powder coat the lower tree with the stem still attached?
Classic 10
Dec 15, 2023 06:54 AM
Badbastard
Jul 7, 2021 12:39 PM
bighdb
2014-2024 Touring Models
May 2, 2020 11:57 AM
UltraNutZ
Oct 25, 2010 10:12 AM
grippper293
Sep 20, 2007 07:43 PM
