Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Softail strut compatability
Old 10-10-2013, 01:27 PM
AJGrey's Avatar
AJGrey
AJGrey is offline
Default Softail strut compatability
Gents, I have a project in the works, I am trying to replace the stock rear fender on my blackline, however the struts I want to use are normal size struts compared to my current blackline struts (blackline has smaller struts and distance from mounting holes are shorter than normal). So, basically, Harley has various models of softails based on the same frame (correct me) if so, the normal struts should bolt up to the rear of the frame as normal (again please correct me) thanks in advance for any input.
(The reason I want normal struts rather than the blackline struts is because I am going a different route making a custom bagger and need the conversion brackets for the hard saddlebags)
Old 04-16-2018, 10:00 PM
97firstHarley's Avatar
97firstHarley
97firstHarley is offline
1st Gear
sad not one answer to this.
redman9
08-20-2015 02:30 AM
TLoud
05-09-2014 12:19 PM
Cosbycreek
04-13-2014 08:28 AM
mphillips
09-26-2010 01:42 PM
FirstRealBike
09-02-2008 12:33 AM
Quick Reply: Softail strut compatability
