Frame as air ride tank
Old 02-01-2015, 12:40 AM
riven150's Avatar
riven150
riven150 is offline
6th Gear
Default Frame as air ride tank
I have air ride on my 13 SG. Talking with someone that works on Harley's he suggests I get an air tank for the suspension. But he said if this was his bike he would make the swingarm into the air tank.
Has anyone done this?
Is this the swingarm or should this be the main frame of the bike?
Any pics on this if someone has done the air tank this way?
Old 02-01-2015, 01:08 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,812 Likes on 1,065 Posts
I suppose it could be done using the swingarm but only with a lot of welding and work. I would think the frame would be too difficult to do.
Old 02-01-2015, 01:30 AM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,991 Likes on 17,500 Posts
Reservoir tank would soften the suspension I would think because it would be a bigger volume of air to compress meaning you'd have to run a higher pressure to compensate, if anything an onboard pump would be preferable. Being able to adjust the shocks on the fly is a huge advantage. Loved the one I ran for a while.
Old 02-01-2015, 04:59 AM
turbotom1052's Avatar
turbotom1052
turbotom1052 is offline
using frame as an air tank is regularly done on drag bikes to store air for an air shifter. As mentioned it would require a bit of welding and even if you utilized the entire frame and swingarm you would have limited capacity. Best to use nitrogen as a fill as its less prone to pressure fluctuations due to temperature.
Old 02-01-2015, 09:50 AM
RK4ME's Avatar
RK4ME
RK4ME is offline
Received 2,221 Likes on 1,385 Posts
Buy the Harley air shock pump, set the air shock pressure at the beginning of the riding season and forget about it.
Old 02-01-2015, 11:27 AM
arlinsg's Avatar
arlinsg
arlinsg is offline
I've heard of people using their engine guard.
Old 02-01-2015, 12:17 PM
riven150's Avatar
riven150
riven150 is offline
6th Gear
Thanks all. I figured the swing arm was all concealed already and I could just tap a line into it? I take it that is not all that can be done?
Old 02-01-2015, 02:30 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
We don't know the swing arm is a sealed cavity, to my knowledge (which is limited) most frames and frame parts are actually vented on purpose,, a small hole is drilled somewhere to allow for temp swing expansion/contraction of metals and air to avoid condensation forming inside that could start rust/corrosion.
As already mentioned, a reservoir of air (like an "air tank") has limited use. Once the air is gone from the tank you can't do anything until the tank is filled again.
Most bikes with adjustable air suspension have pumps.
Old 02-01-2015, 03:30 PM
riven150's Avatar
riven150
riven150 is offline
6th Gear
I do have a compressor already installed. I was thinking of adding a tank for faster input of air into shocks as I ride and change the stiffness.
Old 02-01-2015, 03:33 PM
TwiZted Biker
Air tank doesn't work that way sorry , more volume just means longer recovery times at a given pressure you'd stepping backwards.
Fairbank12
08-06-2019 01:31 PM
Shadowray
Touring Parts
02-28-2016 11:25 AM
gdoc89
01-16-2015 09:35 AM
Kotte
02-09-2011 07:44 AM
Chas63
03-31-2009 05:01 PM
Quick Reply: Frame as air ride tank
