Bouncing voltage gauge
Old 11-28-2015, 06:38 PM
tmac1's Avatar
tmac1
tmac1 is offline
When I disconnected my amp the problem went away. Hooked the amp back up and the bouncing came back. Shortly after the amp burned out. Replaced the amp with a new one and no problem since.
Old 11-28-2015, 07:47 PM
Iron lHorse's Avatar
Iron lHorse
Iron lHorse is offline
Received 2,425 Likes on 1,188 Posts
It could also be a bad stator or loose plug to the stator , maybe ck your AC voltage to see if that's jumping . Could be a bad wire at the point were the wire is solder to the copper windings .
Frogprince
04-09-2024 10:08 AM
Frozen Excursion
02-28-2018 06:23 AM
Biker90
Electrical/Lighting/Alarm
08-25-2017 04:53 PM
Phast Lap
07-09-2009 06:58 AM
scottdoege
03-29-2009 08:59 PM
Quick Reply: Bouncing voltage gauge
