Voltage Gauge
Old Jul 7, 2009 | 06:53 AM
Phast Lap's Avatar
Phast Lap
Default Voltage Gauge
I was out riding my 2006 Street Glide last night and noticed for the first time my voltage gauge needle was pegged all the way over to the right. What would cause this? I am getting to go on a rode trip and don't want to be worried about a break down. This is the first time I have noticed it that far over. It is usually in the middle.
Old Jul 7, 2009 | 07:12 AM
skydoc's Avatar
skydoc
Mine died and was replaced...fairly common issue.
Old Jul 7, 2009 | 08:29 AM
Phast Lap's Avatar
Phast Lap
I just went out to the garage and flipped the ignition switch on and it jumped right up to normal where it is suppose to be. I am not sure it is the gauge. It is never that simple.
Old Jul 7, 2009 | 08:52 AM
rredneckn's Avatar
rredneckn
Sounds like a bad voltage regulator.Check voltage @ batt with engine running @ 2000 rpm if voltage is over 14.2 replace reg.
Old Jul 7, 2009 | 09:19 AM
Phast Lap's Avatar
Phast Lap
What other symptoms would I see if it was the voltage regulator? What would make one go bad? The bike seems to be running great - no dim lights or erratic tach readings. Sorry just don't like the R&R strategy, Espcially on a VR that is $200.00
Old Jul 8, 2009 | 07:22 PM
Phast Lap's Avatar
Phast Lap
OK, checked the voltage @ the battery with the bike running @ a constant 2,000 rpm's and got 14.39 volts. Which I think should be OK (the calibration of the voltmeter could be off by .19 volts). Any comments? should I be worried?
Old Jul 8, 2009 | 08:17 PM
hojones's Avatar
hojones
Like SkyDoc said, the gauge is bad. Mine went out too,
Old Jul 8, 2009 | 11:19 PM
Beemervet's Avatar
Beemervet
Check for a bad ground first.
Old Jul 9, 2009 | 12:56 AM
08UltraRider's Avatar
08UltraRider
Mine did that too and after about 5 minutes it would peg.... Voltage was good and replaced the guage... all was well after that....
Old Jul 9, 2009 | 04:59 AM
Phast Lap's Avatar
Phast Lap
Thanks, guys for all the help.
