Help with saddlebag mounting bolts
Old 06-12-2016, 05:21 PM
Mark Turner's Avatar
Mark Turner
Mark Turner is offline
Stage III
Default Help with saddlebag mounting bolts
I have a 96 wideglide that has saddlebag brackets on it, there are 2 Allen bolts on the outside but I can't see or feel a nut on the inside of the fender
Old 06-12-2016, 05:29 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
It's not a nut, it's a bracket kind of thing that both front and back bolts go into, it supports the fender.
Look up your bike here and look at "rear fender supports" for a diagram.
http://partsfinder.onlinemicrofiche....DER%20SUPPORTS
It's #15,,
Old 06-12-2016, 08:27 PM
Mark Turner
Stage III
Thanks for the info, but I cant get the bolt out. The inside thing just spins and I can't grab it with anything. It just spins
Old 06-12-2016, 09:07 PM
ripn's Avatar
ripn
ripn is offline
Try some Visegrips on the back side to hold that fastener, or be prepared to either cut or drill the heads off the allen bolts.
Old 06-12-2016, 09:27 PM
BigDogIdaho's Avatar
BigDogIdaho
BigDogIdaho is offline
It's basically a T Nut welded onto that bracket. Weld must have broke.
Like said grab it with pliers or vice grips.
Sorg67
EVO
03-20-2017 11:39 AM
xflyerwdavis
10-04-2016 09:37 AM
halnwheels
05-20-2011 12:39 PM
TorturedZen
06-11-2010 01:12 AM
bigheadted
10-02-2008 05:12 PM
Quick Reply: Help with saddlebag mounting bolts
