Alternatives for shifters - Brother lost his foot
Looking for info on alternative shifters as a friend lost his foot in a bad crash, have heard of some air shifters and various things but wanted to hear from some one who has experience or knowledge on types and alternatives.
Of course he is also considering a hand shifter with clutch lever combo but interested in options and what is available.
Bike is a CVO Breakout.
B&B Bright side shifter, widow maker shifter. i talked to many people that said the pingel did not last very long. after losing my left leg i turned my shifter straight up and welded an extension on it and reach over and shift it, simple and it works for a trike. the other two ways would be my next choice.
I'm a left leg BKA and know many bikers with leg problems. The most popular for disabled riders are the Pingle and Kliktronic electric shifters. There is also the Widowmaker tank hand shifter that is popular. If all he is missing is his foot, he can still shift using a heel and toe shifter. That's what I use. You simply lift your leg slightly and drop it on either the front or the rear shifter depending on if you are going or if you are downshifting to stop. The Pingle, Kliktronic and the Widowmaker are probably the 3 most popular. There are a few others, but they are fewer and farther between. Personally, I don't care for the Widowmaker because your left hand is not on the bars when you shift. In a panic situation, I'd like to at least have both hands on the grips, but that's just me. No matter what, your friend needs to wait till he knows for sure what his long term abilities are after all is said and done before he jumps the gun on a shifter. No sense in dropping a grand or more on a shifter he may not even need.
Can't speak for all electric shifters, but Pingle makes a "SPEED SHIFTER" that requires nothing as far as clutch operation and you can use it on street bikes not just race bikes. The Widowmaker uses the clutch but the clutch lever is mounted right on the shift lever. With the Klicktronic you need to use the clutch normally when you first start rolling but my understanding is that you do not need to use the clutch once you get rolling. It's optional once you are rolling when shifting up or down. It shifts really fast like in milliseconds. Some shifters are air driven and those have a bottle that requires you to keep it filled with compressed air.
