I have an 02 road king I changed the transmission fluid , now the neutral light is off in neutral and lights up in gear!!! It was ok before the fluid swap !! Pulled the switch at tranny and reinserted it! Replaced it a month ago ! Any help would be grateful!! Thanks in advance
Sounds like the wrong switch. Your switch is N.C when it should be N.O.. And N.O. when it should be N.C..
The fluid should have nothing to do with the switch.
