Tail light blinks on rev of engine
I am working on a evo and have a led cat eye tail light and when I rev motor the tail light will blink with rpm. I replaced tail light and still the same the turn signals which is reg blubs don't blink. At 2000 RPM running about 14.50 volts coming to battery. cleaned all terminals grounds and positive sides. checked all wiring and when bike is off light works fine but running it is the problem. Need some help on what is causing this problem.
Thanks
Randy
Thanks
Randy
Thanks
Randy
Thanks
Randy
Working on an EVO: what year and model ?
You have an LED cat eye:
Maybe a link to the product so we can get an idea.
You replaced the tail light:
Does this mean you returned to the original factory light assembly and bulbs?
The turn signals do not blink with regular bulbs in factory assembly..correct?
Since it happens only when motor is on:
LED is very directional, if looking straight at light a little vibration could be interpreted as blinking but you have a turn signal issue reported.
What meter are you using to measure voltage?
It is also possible that your voltage regulator is allowing too much voltage to pass.
Do these issues only happen with motor running but all is OK when motor is OFF and only using battery voltage?
Blinking light
ok its a SS 113 motor custom bike Vengeance came with same cat eye light and it is ok when not running. even hooked up old cat eye light back up and old one does the same thing. regulator is pushing 14.50 range at 2000 RPM plan on unhooking regulator tonight and see if that helps. using a fluke to check.
Eagle240
09-17-2012 12:28 PM
redsled
11-12-2011 06:54 PM
