Salt residual
Wash it, rinse well. Not sure what to use on the flat paint.
You can use naval jelly to help clean up the rust.
As for the salt residue, put water in a bucket and pour in a box of baking soda. Add a little bit of baby shampoo and wash your bike with this. The baking soda will neutralize the salt and stop the corrosion (salt will pit your paint microscopically) and the baby shampoo will wash away the junk.
Once you are done washing everything off you can use S100 Total Cycle Cleaner (http://www.s100.com/s100_tcc.htm) to bring the sheen and "new look" back to the black paint.
Also, don't forget to spray inside the rubber boots on the throttle and clutch cables with silicone to prevent any rust from corroding your connections. If you pull back the rubber and you see rust already forming, you can use naval jelly to get rid of the rust. Naval Jelly will damage paint so you don't want to use it on painted surfaces.
Don't neglect your seat(s) or any other leather material either. Use Lexol leather cleaner to clean them good and then Lexol leather conditioner to restore the oils to the leather.
My bikes are always older ones and frequently get compliments on how good they look. I usually just use water, sometimes regular soap, and when drying...I use an oily old shower towel. I like using oily towels on the bikes...and I find it works well helping protect the metals from salty ocean air.
I'm sure there are tons of "magic promising the perfect finish" products out there...I'm just saying the old fashioned method works well for me.
