Alarm Siren installation?
I got one of the little sirens from a guy on Ebay that came with the plug already installed. I have a '17 Road glide and can't figure out where it is supposed to plug in. I have looked at every video on Utube and they are no help. It doesn't appear that any of the cables on the right side wil fit the plug that came with the siren. Thanks for any help.
Received 2,189 Likes
print it or "print to" pdf to make it format for use by humans
Received 14,658 Likes
This is where I found it on my 16 RGU... Under the left side cover, and you're looking for the wire plugging into the siren. the siren is #3 on that diagram. That wire, before I put in the same siren you bought, was plugged into a dummy/holder (like the guy above said) over about where the #10 is indicated in that pic... if I remember right. When you unplug it, it was obvious it was plugged in to a dummy. #3 on that pic is an HD siren slid into its slot, which I assume you don't have, so the slot is open. I put the siren right above where a HD siren would have slid in at, and it does not interfere with the side cover.
Thanks all. I found the cable in the northeast corner and installation was about 4 minutes ( I had to find a screwdriver to get the plug out of the dummy). It chirps on arm and disarm, but I haven't opened it up yet; it would be a little much in the garage. Well worth the $$ and even cheaper if you want to find the plug and get the siren from Radio Shack.
