Fuel pump not priming
03-06-2018, 05:10 PM
2010 Stree Glide..loaded in a truck, ran fine...unloaded it...fuel pump not priming...fuse good...suggestions
03-06-2018, 05:25 PM
Maybe tip sensor was activated somehow during loading/unloading process? I believe that stops the fuel pump from running.
03-06-2018, 05:29 PM
Quote:
Originally Posted by
Dynamick
where is,the tip sensor located?
03-06-2018, 08:47 PM
03-06-2018, 08:52 PM
It's called a bank angle sensor. Google it or look in your manual.
Also check the battery in your key fob. It might just be a coincidence but easy enough to try a new battery.
03-06-2018, 08:58 PM
Is there a "transport mode" that needs to be unlocked?
03-07-2018, 07:55 AM
I thought that there was something that you had to do with newer bikes when transporting them.
03-07-2018, 11:24 AM
larsfum
On bikes with the HD security system, you must place it into transport mode or the bike's motion sensors will make the lights flash, eventually draining your battery.
03-07-2018, 12:22 PM
That's part of the new technology that makes them vastly superior to the older bikes.
Hair53
01-01-2021 02:21 PM
aarcronnie
Electrical/Lighting/Alarm
02-12-2017 03:04 PM
Sean Ferg
08-07-2012 08:37 PM
RjCapp
Exhaust System Topics
05-15-2007 11:34 AM
sbl1985
05-10-2006 02:39 PM
